3D打印又一跨越 蜡像馆在你身边
发表于 2015-5-18 09:21:41 只看该作者 回帖奖励 |倒序浏览 打印 上一主题 下一主题 0 19096
Most 3D-printed objects currently come in a variety of exciting monochromatic colors. You've got red, white, blue and, if you're really lucky, a mix of two colors. And while the objects may have a great deal of detail, the surface will be bland.
现在大多数3D打印成品都是各种各样的单色。有红的,白的,蓝的,如果运气好,还有两种双色的。虽然成品有各种各样的细节,但是表面仍然没有做到栩栩如生。
Now, researchers have found a way to precisely affix complex coloring to objects, making them look somewhat photo-real (and perhaps a bit creepy).
现在,研究者们找到了一种可以对打印成品精准上色的方法。这种方法能够使得上色对象看起来活灵活现(也许看起来还有点毛骨悚然)。
The method, developed by a pair of teams at Zhejiang University and Columbia University, is called computational hydrographic printing. Hydrographic printing is not new; mass manufacturers use it to add repeating patterns to cheaply manufactured objects. It involves a vat of water and thin, pre-printed film, which is sprayed with a softening agent. The object is lowered into water and presses against the film, which stretches to wrap itself around every contour of the object. When the object is removed, it looks as if the pattern was part of the 3D-printing process.
这项技术由浙江大学和哥伦比亚大学的研究小组开发,称为“计算机水纹印刷”。水纹印刷并非是一项新技术。已经有许多制造商利用水纹印刷对廉价成品进行重复花纹的上色。整个过程需要在水槽中完成,上面有预制好的胶片,胶片上面喷印了一层柔软的试剂。需要着色的物体之后慢慢浸入水中,对着胶片按压,使得胶片能够完全包裹物体。
According to researchers, it's nearly impossible to precisely match the object with the film, hence why they usually use repeating patterns — so no one would notice if anything is out of alignment.
研究者表示,胶片要和待着色物体完全吻合是不太可能的,这也是制造商都使用重复花纹的原因——这样如果有什么地方没合上,也没人会发现。
The researchers realized that if they could use the 3D scan of the original object and pre-dip it into a simulated bucket of water and thin-printed film, they could figure out how to position and align more complex prints with objects. However, that simulation can't be run without first using a modified hydrographic printing rig, which is comprised of a vertical, motorized aluminum arm and gripper that moves up and down at 5mm per second, along with a Microsoft Kinect 3D image mapping device.
研究者认识到,如果能用原始对象的3D扫描件,然后事先浸入一个模拟的水箱和薄型胶片,那么他们便可以知道如何把复杂的图案贴合物体。但是,这种模拟如果不改良现有的水纹打印装置,是无法运行的。改良后的水纹打印装置的构成是这样的:有一只垂直的铝制电动臂,还要有一个每秒上下活动5毫米的爪子,同事还要搭配Microsoft Kinect 3D成像设备。
The Kinect's role is crucial. Once researchers have put the object in the gripper, it measures its exact position and orientation in relation to where the 3D film will be placed. It's not until that information has been collected that the researchers can print the film on a standard inkjet printer, which will then include the necessary image deformations and account for the image stretch that will occur during the dip — ones that will make the final melded object look just right.
Kinect的角色至关重要。当研究者把扫描对象放在爪子中,根据三维胶片的位置,装置就可以测量扫描对象的确切位置和方向。直到信息搜集完毕,研究者才能把胶片放在一个标准的喷墨打印机上,用以处理图像变形以供在浸入时的图像拉伸。
In a video announcing the breakthrough, the Zhejiang University and Columbia University teams show off a printed tiger mask, zebra, single dip-globe and a 3D-printed cat. For the cat, the team performed three dips to wrap the initially monochrome kitten in a photo-realistic skin. The result has that uncanny valley problem of looking almost real, but not quite.
在一段宣布这项突破的视频中,浙江大学和哥伦比亚的研究团队展示了老虎面具,斑马,猫等成品。关于这只猫,研究团队演示了三次浸入的方法,把原来单色的小猫包裹上了极具真实感的皮肤。最终的效果看起来可以乱真,但是并不完美。
There are some limitations. Researchers note that they cannot easily cover objects featuring highly concave surfaces or any surface that might be hidden from view or scanning. Color blending and precision is also a bit of a challenge, and when the film stretches out significantly, some color can become lighter than the original color.
当然也存在一些局限,研究者表示,他们不能很轻易给有巨大凹面或者扫描不到的地方着色。颜色的混合和精度也是一项挑战,当胶片被拉伸过度的时候,有一些颜色也要比原色更浅一些。
Even with those limitations, this relatively simple method for adding complex patterns and photo-real imagery to monochromatic 3D-printed objects shows promise. One can imagine someone scanning and printing a lifelike 3D model of a person's head, then using a high-res photograph to print out a face and sides, top and back of the head. Multiple computationally guided dips would then create a truly scary bust.
尽管有着各种局限,但是对于把复杂图案和现实照片加到单色三维物体,这种方法还是很有前景的。我们可以想象:当你扫描并且打印了一个人的三维头部模型,然后把高分辨率的照片印到脸部和侧面,还有顶部和后部。通过多次计算机导航浸入印刷可以制作出一个真正让人惊悚的东西。
GMT+8, 2026-11-17 18:10 , Processed in 0.069019 second(s), 9 queries , Gzip On, Redis On.
