高温 3D 打印耐热且尺寸稳定的模型
发表于 2015-1-29 14:07:54 只看该作者 回帖奖励 |倒序浏览 打印 上一主题 下一主题 0 26131
耐高温材料能够模拟标准塑料的热性能,是静态部件热测试的理想之选。高温 PolyJet 光聚合物可以与橡胶类材料结合使用生成一系列用途广泛且具有可调性质的材料。
3D Printing With High Temperature Material
High Temperature material (RGD525, white) combines heat resistance with exceptional dimensional stability. The material can simulate the thermal performance of engineering plastics and is ideal for testing applications such as hot-air flow or hot-water flow in pipes and faucets.
Objet High Temperature material has a heat deflection temperature of 63–67 C (145-153 F) upon removal from the printer. Thermal post treatment in a programmable oven can increase this to 75-80 C (167-176 F).
Simulate High Temperature Parts With Improved Functional Performance
Combining High Temperature material with Rubber-like materials produces varying Shore A values, gray shades and rigid functional materials with higher temperature resistance. The composite also enables printing high-temperature parts with over-molding.
Wide Range of Applications
High Temperature PolyJet photopolymer is useful for many applications including:
    Form, fit and thermal functional testing of static parts
    High-definition parts requiring excellent surface quality
    Exhibition modeling under strong lighting conditions
    Post-processing including painting, gluing or metallization processes
    Models in transit
    Taps, pipes and household appliances
    Hot air and hot water testing
GMT+8, 2026-10-24 01:54 , Processed in 0.074342 second(s), 11 queries , Gzip On, Redis On.
